Salta al contenuto principale
JBL Clip 3 Button Board Replacement
Cosa ti serve
  1. JBL Clip 3 Button Board Replacement, Button Board: passo 1, immagine 1 di 2 JBL Clip 3 Button Board Replacement, Button Board: passo 1, immagine 2 di 2
    • Insert an opening tool between the speaker grille and speaker housing and pry around the entire perimeter of the device until the grille is released.
    • A strong adhesive attaches the grill to the housing and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Button Board Replacement: passo 2, immagine 1 di 2 JBL Clip 3 Button Board Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Button Board Replacement: passo 3, immagine 1 di 1
    • Separate the speaker housing from the rest of the body.
    • Carefully lift the speaker housing since there are components that are connected to the speaker housing.
    • The speaker housing and the body are not glued together.
  4. JBL Clip 3 Button Board Replacement: passo 4, immagine 1 di 2 JBL Clip 3 Button Board Replacement: passo 4, immagine 2 di 2
    • Carefully remove the 2-pin and 4-pin connectors from the motherboard.
    • Tweezers can also be used to remove the 2-pin and 4-pin connectors.
  5. JBL Clip 3 Button Board Replacement: passo 5, immagine 1 di 3 JBL Clip 3 Button Board Replacement: passo 5, immagine 2 di 3 JBL Clip 3 Button Board Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the two 6.3 mm screws.
    • Carefully remove the internal speaker from the speaker housing.
    • This step is completely optional; completing this step will help unclutter the speaker housing, allowing you to unscrew the last final screws easier.
  6. JBL Clip 3 Button Board Replacement: passo 6, immagine 1 di 3 JBL Clip 3 Button Board Replacement: passo 6, immagine 2 di 3 JBL Clip 3 Button Board Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the two 6.3 mm screws from the button board.
    • Carefully lift and remove the button board from the speaker housing.
    • When reassembling your device, remember to use super glue to reattach the grille to the speaker housing.
Conclusione
Adrian Mayorga
Membro da: 10/21/24
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 320
