Salta al contenuto principale
JBL Clip 2 Speaker Replacement
Cosa ti serve
  1. JBL Clip 2 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: passo 2, immagine 1 di 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: passo 3, immagine 1 di 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: passo 4, immagine 1 di 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
Conclusione
Altre 4 persone hanno completato questa guida.
Michael Hong
Membro da: 02/01/17
1.014 Reputazione
5 Guide realizzate
UW Tacoma, Team 2-2, Rose Winter 2017 Membro di UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Membri
7 Guide realizzate
6 Commenti
If no parts are required what are you replacing the speaker with?
Tom - Replica
Tom is right you know!
edward felix - Replica
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Replica
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Replica
Hi, where I can buy the speaker please? Thank you.
Govan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 79
Tutti i Tempi: 6,360
