Salta al contenuto principale
JBL Clip 2 Carabineer Mount Replacement
Cosa ti serve
  1. JBL Clip 2 Carabineer Mount Replacement, Carabineer Mount: passo 1, immagine 1 di 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Carabineer Mount Replacement: passo 2, immagine 1 di 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Carabineer Mount Replacement: passo 3, immagine 1 di 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Carabineer Mount Replacement: passo 4, immagine 1 di 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Carabineer Mount Replacement: passo 5, immagine 1 di 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Carabineer Mount Replacement: passo 6, immagine 1 di 1
    • Slightly move the motherboard to the side to reveal the sides of battery, carefully using the blue plastic opening tool, remove the battery from the speaker casing.
    • Be careful not to disconnect any soldered wires connected to the motherboard and speaker casing.
  7. JBL Clip 2 Carabineer Mount Replacement: passo 7, immagine 1 di 1
    • There are two 3 mm T8 screws holding the carabineer in place, remove these two screws.
Conclusione
Altre 3 persone hanno completato questa guida.
Michael Hong
Membro da: 02/01/17
1.014 Reputazione
5 Guide realizzate
UW Tacoma, Team 2-2, Rose Winter 2017 Membro di UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Membri
7 Guide realizzate
2 Commenti
i want to find that part ,dou you have web link to by
breakdancesok - Replica
where can i find this piece please
Daniel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 91
Tutti i Tempi: 8,949
