Salta al contenuto principale
JBL Charge Speaker Replacement
Cosa ti serve
  1. JBL Charge Speaker Replacement, Disassembling JBL Charge Casing: passo 1, immagine 1 di 3 JBL Charge Speaker Replacement, Disassembling JBL Charge Casing: passo 1, immagine 2 di 3 JBL Charge Speaker Replacement, Disassembling JBL Charge Casing: passo 1, immagine 3 di 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Speaker Replacement: passo 2, immagine 1 di 2 JBL Charge Speaker Replacement: passo 2, immagine 2 di 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Speaker Replacement: passo 3, immagine 1 di 2 JBL Charge Speaker Replacement: passo 3, immagine 2 di 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Speaker Replacement: passo 4, immagine 1 di 2 JBL Charge Speaker Replacement: passo 4, immagine 2 di 2
    • Use a nylon spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Speaker Replacement: passo 5, immagine 1 di 2 JBL Charge Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Speaker Replacement: passo 6, immagine 1 di 2 JBL Charge Speaker Replacement: passo 6, immagine 2 di 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Speaker Replacement: passo 7, immagine 1 di 2 JBL Charge Speaker Replacement: passo 7, immagine 2 di 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Speaker Replacement, Motherboard: passo 8, immagine 1 di 1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Speaker Replacement: passo 9, immagine 1 di 2 JBL Charge Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Speaker Replacement: passo 10, immagine 1 di 1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Speaker Replacement: passo 11, immagine 1 di 2 JBL Charge Speaker Replacement: passo 11, immagine 2 di 2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Speaker Replacement, Speaker: passo 12, immagine 1 di 1
    • Using the PH1 screwdriver, remove the 9mm Phillips screw that connects the black tube to the device's interior.
  13. JBL Charge Speaker Replacement: passo 13, immagine 1 di 2 JBL Charge Speaker Replacement: passo 13, immagine 2 di 2
    • Slowly but firmly pull the grey cap off the device. This will provide complete access to the speakers.
  14. JBL Charge Speaker Replacement: passo 14, immagine 1 di 2 JBL Charge Speaker Replacement: passo 14, immagine 2 di 2
    • Each speaker is held in place with two 9mm Phillips screws. Remove the screws using the PH1 screwdriver head.
    • If you are replacing the left speaker, remove the screws and speaker on your right.
    • If you are replacing the right speaker, remove the screws and speaker on your left.
  15. JBL Charge Speaker Replacement: passo 15, immagine 1 di 1
    • Pull the speaker out of the casing.
Conclusione
Altre 14 persone hanno completato questa guida.
Cal Poly, Team 12-4, Lancaster Spring 2015 Membro di Cal Poly, Team 12-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G4
2 Membri
17 Guide realizzate
11 Commenti
Donde encuentro las bocinas no sirven la que tiene
feliper233 - Replica
Donde puedo conseguir las bocinas?
Where can I get gthe replacement speaker?
rohit jayendra - Replica
where can i get replaicment speaker?
tamaerocksxd - Replica
Where do I get the replacement speakers
Robert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 196
Tutti i Tempi: 79,636
