Salta al contenuto principale
Introduzione
Removing the motherboard will allow access to most of the internal components.
  1. Make sure the device is powered off before you begin to disassemble the speaker. Remove the trim from the speaker using a jimmy or metal spudger. Remove the trim from the speaker using a jimmy or metal spudger.
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover. Remove the battery cover and set the cover aside.
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment. Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. Use a nylon spudger to lift the battery out of the device. Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Use a nylon spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver. Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together. Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. Once the back casing is open, disconnect the three white connectors from the motherboard. Remove the upper casing.
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. Remove the 9 mm Phillips screw in the corner of the motherboard.
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. Remove the motherboard from the casing  by lifting the corner of the board out of the device. If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. Disconnect the two white connectors from the bottom of the motherboard.
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. Pull down on the black clip holding the ribbon cable in place. Pull the ribbon cable from the connector using the blue tab.
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
Conclusione
Altre 7 persone hanno completato questa guida.
Jake Bertholf
Membro da: 01/04/2015
347 Reputazione
2 Guide realizzate
Cal Poly, Team 12-1, Lancaster Spring 2015 Membro di Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Membri
10 Guide realizzate
13 Commenti
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
hector - Replica
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
nyancatsarecute -
i have the same problem
Denny Berroa - Replica
Hello, mine doesn't emit any sound, bluetooth is connected, buttons are working, could it be that some audio cable inside is disconnected?
giubo - Replica
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
djcriztorey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 97
Tutti i Tempi: 27,817
