Salta al contenuto principale
JBL Charge 5 Fabric Case Replacement
Cosa ti serve
  1. JBL Charge 5 Fabric Case Replacement, Fabric Case: passo 1, immagine 1 di 3 JBL Charge 5 Fabric Case Replacement, Fabric Case: passo 1, immagine 2 di 3 JBL Charge 5 Fabric Case Replacement, Fabric Case: passo 1, immagine 3 di 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Fabric Case Replacement: passo 2, immagine 1 di 3 JBL Charge 5 Fabric Case Replacement: passo 2, immagine 2 di 3 JBL Charge 5 Fabric Case Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Fabric Case Replacement: passo 3, immagine 1 di 3 JBL Charge 5 Fabric Case Replacement: passo 3, immagine 2 di 3 JBL Charge 5 Fabric Case Replacement: passo 3, immagine 3 di 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 108
Tutti i Tempi: 484
