Introduzione
If any of the three ports on your JBL Charge 3 (AUX, USB, charging) are not functioning, they may need replacing. If you wish to replace only one of the ports rather than the whole assembly, you will need to know how to solder. Follow iFixit's Soldering Guide to learn more.
Cosa ti serve
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Pull apart your cover gently from both sides and remove it from the speaker housing.
@KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
Very good guide! Pics and descriptions make this easy!
There is a step missing here. How do you remove the rubber cover that covers the port?
Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
Take out the four 8mm Phillips #1 screws out of the port bay cover.
Wedge your plastic opening tool around the port bay to remove it.
and then wiggle it directly (almost radially from the cylinder) out until you see the cables shown in the next step.
Be careful not to damage the plastic gasket as you pull it out,
Disconnect the two bundled cable connector from the port bay.
there’s not much room to get you fingers in. Again I used prying tools to help me get the two connectors off the PCB
How do i get another port bay
Remove the three 8mm Phillips #1 screws from the port bay circuit board.
Pull the port bay cover off of the circuit board.
Be careful not to break the 2 plastic lugs you can see just below (on the photo) the 2 screws at the edges
Desolder the USB, MicroUSB, or AUX port off of the circuit board.
Salve, dove posso ordinare la presa usb piccola di ricarica, c’è un sito apposito?
Altre 35 persone hanno completato questa guida.
15 Commenti
Is there a place to buy an entire replacement port bay?
Found the whole assembly on line for 30 bucks. Or a usb port for five from jbl
Can u share a link? Need a new port bay!
anyone have the charging ways of this board i have 2 pads missing and would like to run the lines
yeah i need that too. the micro usb broke off the mb
Hi,
the pinout for the micro-usb socket, looking from the top side (3.5mm audio socket is on my left and USB port is on my right):
1. Most left line, line #1 on the micro-usb connector is GND. Goes to the pin #5 (also connected to #6 and #7) of the large 11pin connector labeled J602.
2. Line #2 on the micro-usb connector is ID which is connected to the GND - pin #5 (also connected to #6 and #7) of the large 11pin connector labeled J602.
3. Line #3 on the micro-usb connector is DATA +, which goes to pin #4 of the large 11pin connector labeled J602.
4. Line #4 on the micro-usb connector is DATA -, which goes to pin #3 of the large 11pin connector labeled J602.
5. Line #5 (most right) on the micro-usb connector is VCC/+5V, which goes to pin #1 (also connected to #2) of the large 11pin connector labeled J602.
Simon -
Welche Maße haben die Ladebuchsen?
Where can I buy the port bay
Wo kann man bauteile bestellen ? Bitte Antwort.
Habe heute die SMD Micro USB Ladebuchse ausgetauscht. Wie man diese Reparatur in 15min erledigen will ist mir ein Rätzel. Und einfach eine THT und SMD Buchse umlöten, benötigt wirklich Fachwissen und die nötigen Lötskills. Eher 30 bis 45 minuten mit dem richtigen Werkzeug und Microskop!
Ersatzteil:
✅ JBL Charge 3 Bluetooth Lautsprecher Micro USB DC Buchse Ladebuchse Connector
https://www.ebay.de/itm/163349223128
Falls Sie beim Austausch der Buchse Hilfe benötigen:
✅ REPARATUR Austausch Micro USB Ladebuchse JBL Charge 3 Bluetooth Lautsprecher
Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
Frank Puranik - Replica
the front grill is supposed to be first not the back the back has longer while the front has shorter clip
Water Bass Tester (Water BT) - Replica
There are two Phillips head screws to remove before prying the cover off
jason - Replica
Where in south Africa can I buy jbl charge3 port bay replacement
Donovan Fransman - Replica
There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
john Ramirez - Replica
Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
ralphkeneth_gomz - Replica
Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
Rowan Darko - Replica
How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
Bukowski101 - Replica
