Salta al contenuto principale
JBL Charge 3 Front Cover Replacement
Cosa ti serve
  1. JBL Charge 3 Front Cover Replacement, Front Cover: passo 1, immagine 1 di 3 JBL Charge 3 Front Cover Replacement, Front Cover: passo 1, immagine 2 di 3 JBL Charge 3 Front Cover Replacement, Front Cover: passo 1, immagine 3 di 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Front Cover Replacement: passo 2, immagine 1 di 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
Conclusione
Altre 6 persone hanno completato questa guida.
Aidan Hays
Membro da: 10/08/18
3.875 Reputazione
2 Guide realizzate
Cal Poly, Team S13-G1, White Fall 2018 Membro di Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Membri
26 Guide realizzate
2 Commenti
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - Replica
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 107
Tutti i Tempi: 9,074
