Salta al contenuto principale
JBL Charge 3 Button Replacement
Cosa ti serve
  1. JBL Charge 3 Button Replacement, Front Cover: passo 1, immagine 1 di 3 JBL Charge 3 Button Replacement, Front Cover: passo 1, immagine 2 di 3 JBL Charge 3 Button Replacement, Front Cover: passo 1, immagine 3 di 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Button Replacement: passo 2, immagine 1 di 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Button Replacement, Button: passo 3, immagine 1 di 2 JBL Charge 3 Button Replacement, Button: passo 3, immagine 2 di 2
    • Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
    • Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
  4. JBL Charge 3 Button Replacement: passo 4, immagine 1 di 2 JBL Charge 3 Button Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Flip open the top flap on the ZIF connector.
    • Gently pull out the ZIF connector cable with tweezers.
Conclusione
Altre 15 persone hanno completato questa guida.
Sunmin Yoon
Membro da: 10/30/18
2.027 Reputazione
2 Guide realizzate
Cal Poly, Team S13-G1, White Fall 2018 Membro di Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Membri
26 Guide realizzate
4Commenti sulla guida
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - Replica
Where do i buy new buttons?
Thomas Bjerregaard - Replica
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - Replica
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 192
Tutti i Tempi: 27,293
