Salta al contenuto principale
Introduzione
Your battery may need to be replaced if it doesn't hold a charge or is not charging at all. The JBL Charge 3 has a 6000mAH battery.
Parti
Nessuna parte specificata.
  1. Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover. Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place. Repeat this process for all four edges of the front cover.
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Replica
  2. Pull apart your cover gently from both sides and remove it from the speaker housing.
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Include dissembling the plastic cover? cover?
    KanGoon - Replica
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
  3. Remove the two 8mm Phillips #1 screws from the tabs. NOTE: There may be only one screw. NOTE: There may be only one screw.
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  4. Insert  the plastic opening tools underneath both tabs. Insert  the plastic opening tools underneath both tabs.
    • Insert the plastic opening tools underneath both tabs.
  5. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  6. Twist and pull open the passive radiator. The left radiator twists off counterclockwise; the right clockwise.
    • Twist and pull open the passive radiator. The left radiator twists off counterclockwise; the right clockwise.
  7. Repeat all previous steps for the other passive radiator. NOTE: only the right radiator needs to be removed for changing the battery.
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
  8. Remove the six 8mm Phillips #1 screws from the outer battery cover. Peel the outer battery cover away from the speaker housing. Peel the outer battery cover away from the speaker housing.
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
  9. Remove the seven 8mm Phillips #1 screws from interior battery cover. Remove the interior battery cover. Remove the interior battery cover.
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
  10. Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard. Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
  11. Pull the battery and battery cable out from their housing.
    • Pull the battery and battery cable out from their housing.
Conclusione
Altre 5 persone hanno completato questa guida.
Jack Ng
Membro da: 08/10/2018
400 Reputazione
3 Guide realizzate
Cal Poly, Team S13-G1, White Fall 2018 Membro di Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
4 Membri
14 Guide realizzate
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 54
Ultimi 7 Giorni: 304
Ultimi 30 Giorni: 1,365
Tutti i Tempi: 3,831
