Salta al contenuto principale
JBL Charge 2 Speakers Replacement
Cosa ti serve
  1. JBL Charge 2 Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Speakers Replacement: passo 2, immagine 1 di 2 JBL Charge 2 Speakers Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Speakers Replacement: passo 3, immagine 1 di 2 JBL Charge 2 Speakers Replacement: passo 3, immagine 2 di 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Speakers Replacement: passo 4, immagine 1 di 2 JBL Charge 2 Speakers Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Speakers Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Speakers Replacement: passo 6, immagine 1 di 3 JBL Charge 2 Speakers Replacement: passo 6, immagine 2 di 3 JBL Charge 2 Speakers Replacement: passo 6, immagine 3 di 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Speakers Replacement, Speakers: passo 7, immagine 1 di 1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Speakers Replacement: passo 8, immagine 1 di 1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Speakers Replacement: passo 9, immagine 1 di 1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S2-G4, Passmore Fall 2017 Membro di USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 49
Tutti i Tempi: 4,643
