Salta al contenuto principale
JBL Charge 2 Battery Replacement
Cosa ti serve
  1. JBL Charge 2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the screen cover from the speaker using a metal spudger.
    Please note BOTH screen covers should be removed for the battery replacement
    Shane Phillips - Replica
    Only the rear screen need be removed. There will be the battery housing(black plastic piece), remove 5 black screws with #1 Phillips. Gently working from side to side with spudger tool dislodge battery housing. Gently unplug battery connector, and remove battery housing. Remove 1 black Phillips screw and remove cover. Remove battery.
    1STEIN69 - Replica
  2. JBL Charge 2 Battery Replacement: passo 2, immagine 1 di 2 JBL Charge 2 Battery Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
    To remove the battery, only the cap and passive radiator containing the battery terminal needs to be removed.
  3. JBL Charge 2 Battery Replacement: passo 3, immagine 1 di 2 JBL Charge 2 Battery Replacement: passo 3, immagine 2 di 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
    It’s not recommended to twist the radiator as there alignment pins on the body of the device. This can be pried away by hand or with a plastic spudger tool
  4. JBL Charge 2 Battery Replacement: passo 4, immagine 1 di 2 JBL Charge 2 Battery Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Battery Replacement: passo 6, immagine 1 di 3 JBL Charge 2 Battery Replacement: passo 6, immagine 2 di 3 JBL Charge 2 Battery Replacement: passo 6, immagine 3 di 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
Conclusione
Altre 10 persone hanno completato questa guida.
USF Tampa, Team S2-G4, Passmore Fall 2017 Membro di USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 Membri
8 Guide realizzate
3 Commenti
Thanks for the manual! Easy repair this way.
Jeroen Cox - Replica
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Rogelio Fernandez - Replica
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
Vasudev Chiratla -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 56
Ultimi 30 Giorni: 241
Tutti i Tempi: 19,509
