Salta al contenuto principale
Ion Air Pro Record and Stop Switch Replacement
Cosa ti serve
  1. Ion Air Pro Record and Stop Switch Replacement, Record and Stop Switch: passo 1, immagine 1 di 1
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Ion Air Pro Record and Stop Switch Replacement: passo 2, immagine 1 di 2 Ion Air Pro Record and Stop Switch Replacement: passo 2, immagine 2 di 2
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Ion Air Pro Record and Stop Switch Replacement: passo 3, immagine 1 di 1
    • Remove black aluminum casing as shown.
  4. Ion Air Pro Record and Stop Switch Replacement: passo 4, immagine 1 di 1
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  5. Ion Air Pro Record and Stop Switch Replacement: passo 5, immagine 1 di 1
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
Conclusione
UW Stout, Team S6-G2, Ogden Fall 2018 Membro di UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 392
