Salta al contenuto principale
Iomega Z100S2 Disk Reader Replacement
Cosa ti serve
  1. Iomega Z100S2 Disk Reader Replacement, Case: passo 1, immagine 1 di 2 Iomega Z100S2 Disk Reader Replacement, Case: passo 1, immagine 2 di 2
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Disk Reader Replacement: passo 2, immagine 1 di 1
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Disk Reader Replacement: passo 3, immagine 1 di 1
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Disk Reader Replacement: passo 4, immagine 1 di 2 Iomega Z100S2 Disk Reader Replacement: passo 4, immagine 2 di 2
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Disk Reader Replacement: passo 5, immagine 1 di 2 Iomega Z100S2 Disk Reader Replacement: passo 5, immagine 2 di 2
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  6. Iomega Z100S2 Disk Reader Replacement, Disk Reader: passo 6, immagine 1 di 2 Iomega Z100S2 Disk Reader Replacement, Disk Reader: passo 6, immagine 2 di 2
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Disk Reader Replacement: passo 7, immagine 1 di 1
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Disk Reader Replacement: passo 8, immagine 1 di 2 Iomega Z100S2 Disk Reader Replacement: passo 8, immagine 2 di 2
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Disk Reader Replacement: passo 9, immagine 1 di 1
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Disk Reader Replacement: passo 10, immagine 1 di 2 Iomega Z100S2 Disk Reader Replacement: passo 10, immagine 2 di 2
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Disk Reader Replacement: passo 11, immagine 1 di 1
    • Lift the reader up and out from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 7-53, Amido Fall 2010 Membro di Cal Poly, Team 7-53, Amido Fall 2010
CPSU-AMIDO-F10S7G53
4 Membri
6 Guide realizzate
2 Commenti
Great guide exactly what I was looking for.
Jim Schmidt - Replica
Zip disks were awesome, and they still are they fit that niche between needing something small in capacity but not large enough for a USB flash drive.
Trevor Rawlinson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 6,095
