Salta al contenuto principale
Iomega MiniMax Disassembly
Cosa ti serve
    • Before you begin:
    • If your disk is mounted and running, be sure to eject it from your desktop.
    • Turn power off via the physical switch on the rear of the enclosure.
    • Remove all cables from the rear of the device. Make note of which cables were used in which ports if you have multiple devices and may mix them up. It's best to use the exact same ports to eliminate any potential issues in case you have a bad port.
  1. Iomega MiniMax Disassembly, Remove screws.: passo 2, immagine 1 di 1
    • On the rear of the device, remove the 2 philips screws, with a small screwdriver. Screws are both the same.
    • (Sorry for the poor quality photos.)
  2. Iomega MiniMax Disassembly, Loosen upper case.: passo 3, immagine 1 di 2 Iomega MiniMax Disassembly, Loosen upper case.: passo 3, immagine 2 di 2
    • Using a thin rigid tool (or old credit card), start on the rear, wedge it into the gap between the upper and lower cases as shown.
    • Slowly work your way around the device while gently pulling up on the separating cover.
    • Make sure to use care near the rear center, to avoid breaking a single center tab at this location. By the time you get to the front, the upper case should almost be falling off, and can be easily removed.
    You should make it clear in your first picture that you are moving the card from the left to the right. Then you follow all the way around the device and meet at the rear where you started (and where the fragile tab is located)
    You should clarify that in your second picture — where you show the fragile tab — the image is taken looking DOWN into the device.
    Kirk Carver - Replica
    I WASN’T moving left to right.
    You should clarify that in your second picture the image is taken looking DOWN into the device.
    You are taking a lid off. Every picture of the inside like that will be looking down. Also obvious from the description, and the hardware pictured inside.
    scottbernardis -
  3. Iomega MiniMax Disassembly, Remove upper case.: passo 4, immagine 1 di 3 Iomega MiniMax Disassembly, Remove upper case.: passo 4, immagine 2 di 3 Iomega MiniMax Disassembly, Remove upper case.: passo 4, immagine 3 di 3
    • Remove upper case. One each of the Left, Front, and Right sides, you can see 3 tabs (per side), that were holding the case on. On the rear you will see the fragile clip that should be removed last, if possible.
Conclusione
Altre 10 persone hanno completato questa guida.
5 Commenti
EXACTLY what I was seeking!
kend - Replica
Thanks for the tip! What kind of internal bus does the drive use, should I want to upgrade it?
Mariano B. - Replica
No idea on the internal bus. Not my area of expertise.
scottbernardis - Replica
The hardest part was finding an old credit card! BTW, the hard drive in my unit is a 2TB Seagate Barracuda LP with a SATA interface. I’m considering replacing it with a SSD.
Jon Noxon - Replica
This is exactly what I was looking for. I have an old one that stopped working and I want to replace the drive.
Noah Preston - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 54
Tutti i Tempi: 6,377
