Salta al contenuto principale
Internal Audio Adapter Jack Replacement
Cosa ti serve
  1. Internal Audio Adapter Jack Replacement, Exterior Housing: passo 1, immagine 1 di 3 Internal Audio Adapter Jack Replacement, Exterior Housing: passo 1, immagine 2 di 3 Internal Audio Adapter Jack Replacement, Exterior Housing: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iOpener
    $19.99
    Compra
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
  2. Internal Audio Adapter Jack Replacement, Lower Half Casing: passo 2, immagine 1 di 3 Internal Audio Adapter Jack Replacement, Lower Half Casing: passo 2, immagine 2 di 3 Internal Audio Adapter Jack Replacement, Lower Half Casing: passo 2, immagine 3 di 3
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
  3. Internal Audio Adapter Jack Replacement: passo 3, immagine 1 di 3 Internal Audio Adapter Jack Replacement: passo 3, immagine 2 di 3 Internal Audio Adapter Jack Replacement: passo 3, immagine 3 di 3
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
  4. Internal Audio Adapter Jack Replacement, Preliminary Main Board: passo 4, immagine 1 di 2 Internal Audio Adapter Jack Replacement, Preliminary Main Board: passo 4, immagine 2 di 2
    • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
  5. Internal Audio Adapter Jack Replacement: passo 5, immagine 1 di 1
    • Peel away the black tape covering the red wires that connect to the PCB.
  6. Internal Audio Adapter Jack Replacement: passo 6, immagine 1 di 1
    • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
    • Slowly lift the PCB away from the rest of the device
    • Remove the ribbon by first removing the brown insert piece from the connector on the button board
    • Pull the ribbon out of the connector on the button board by the blue tab.
  7. Internal Audio Adapter Jack Replacement: passo 7, immagine 1 di 1
    • Carefully disconnect the white 11-pin connector from the main board.
    • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
  8. Internal Audio Adapter Jack Replacement, Internal Audio Adapter Jack: passo 8, immagine 1 di 1
    • A strip of black tape covers the grey and purple wire cluster that connects to the internal audio printed circuit board. Carefully peel this tape away.
  9. Internal Audio Adapter Jack Replacement: passo 9, immagine 1 di 1
    • Remove the four 7 mm screws that hold the PCB in place; you will need a Phillips #1 driver to do this. You may need to move some wires out of the way to access one of these screws.
  10. Internal Audio Adapter Jack Replacement: passo 10, immagine 1 di 2 Internal Audio Adapter Jack Replacement: passo 10, immagine 2 di 2
    • Carefully lift and remove the black plastic bracket.
    • Lift the PCB away from the rest of the device.
Conclusione
Jerrell
Membro da: 04/23/14
730 Reputazione
7 Guide realizzate
Cal Poly, Team 11-50, Amido Spring 2014 Membro di Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Membri
8 Guide realizzate
Un commento
My conecctor not charging ipl 24 ihome
Rafia Sohail - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,324
