Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
This guide details the steps to take off the rear cover of your Inter-tel IP 8660.
Parti
Nessuna parte specificata.
  1. Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out. 8 mm long 11 mm long
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Lift up the back cover and set it aside.
    • Lift up the back cover and set it aside.
Conclusione
Cal Poly, Team 11-24, Maness Winter 2012 Membro di Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 477
