Salta al contenuto principale
Inter-tel IP 8660 Button Pad Replacement
Cosa ti serve
  1. Inter-tel IP 8660 Button Pad Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Button Pad Replacement: passo 2, immagine 1 di 3 Inter-tel IP 8660 Button Pad Replacement: passo 2, immagine 2 di 3 Inter-tel IP 8660 Button Pad Replacement: passo 2, immagine 3 di 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Button Pad Replacement: passo 3, immagine 1 di 1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Button Pad Replacement, Internal speaker: passo 4, immagine 1 di 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Button Pad Replacement: passo 5, immagine 1 di 1
    • Lift up the speaker.
  6. Inter-tel IP 8660 Button Pad Replacement, Button Pad: passo 6, immagine 1 di 1
    • Lift up the motherboard and set aside
  7. Inter-tel IP 8660 Button Pad Replacement: passo 7, immagine 1 di 1
    • Peel off all rubber button covers.
  8. Inter-tel IP 8660 Button Pad Replacement: passo 8, immagine 1 di 1
    • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Conclusione
Cal Poly, Team 11-24, Maness Winter 2012 Membro di Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 874
