Salta al contenuto principale
Instant Pot Smart-60 Plastic Base Replacement
Cosa ti serve
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: passo 1, immagine 1 di 2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: passo 1, immagine 2 di 2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: passo 2, immagine 1 di 1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: passo 3, immagine 1 di 1
    • Flip the Instant Pot over on its top so that the base is facing upward.
    Where can I buy that base. Thank you.
    Belinda Berka - Replica
  4. Instant Pot Smart-60 Plastic Base Replacement: passo 4, immagine 1 di 1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: passo 5, immagine 1 di 1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
    Where can I get this base plate?
    Muhammad Abdullah Sabooani - Replica
    That small round base. Where can you buy one. Thank you.
    I am also looking for my pot. Any suggestions?
    Sai Parmar - Replica
    I need one tô. Please advise. Thanks!
    le.dieuai - Replica
    Where did you get the base? I need one
    Sarah Parker - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
paola alvarez
Membro da: 01/24/18
534 Reputazione
4 Guide realizzate
Cal Poly, Team S1-G4, Livingston Winter 2018 Membro di Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Membri
6 Guide realizzate
13 Commenti
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - Replica
Hello where can I buy the plastic base
Maureen - Replica
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - Replica
Did you ever find out where you can buy this part.
Thank you. Belinda
Do you carry the replacement for this. Thanks
khai01 - Replica
Has anyone found the replacement part? It isn't available through Instant Pot customer service.
Patti Gregory - Replica
On my Instant Pot Nova Plus series, the screw on the bottom plate is a T15 instead of Philips #2
Cynthia Roessler - Replica
Hi
We also need a new plastic base as ours got accidently melted on the stove.
Any sources for replacement part
Thanks
Doug - Replica
Does anyone know where to by the plastic bottom
pljonesvfd11 - Replica
Hi,
We also need a new plastic base as ours got accidentally melted on the stove.
Thiago Pontelli - Replica
Hey I would like to buy this, and could I know how I can get it?
Kaylee Chu - Replica
I need one - the whole base. Who else did burn one :-) ??
Were do I get this item? All other appliances I'm used to have a blow-up drawing, where every single item usually can be sourced.
Had higher expectations for Instant Pot in regards to spare parts, one of the reasons I did not want a knock-off,
Basti_D - Replica
If the base can’t be found, what is the point of having instructions on how to repair it? I can’t find a base either!
Gerald Crusader - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 6,667
