Salta al contenuto principale
Instant Pot Smart-60 Plastic Base Replacement
Cosa ti serve
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: passo 1, immagine 1 di 2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: passo 1, immagine 2 di 2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: passo 2, immagine 1 di 1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: passo 3, immagine 1 di 1
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: passo 4, immagine 1 di 1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: passo 5, immagine 1 di 1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
Conclusione
Altre 3 persone hanno completato questa guida.
paola alvarez
Membro da: 01/24/18
534 Reputazione
4 Guide realizzate
Cal Poly, Team S1-G4, Livingston Winter 2018 Membro di Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Membri
6 Guide realizzate
13 Commenti
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - Replica
Hello where can I buy the plastic base
Maureen - Replica
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - Replica
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - Replica
Do you carry the replacement for this. Thanks
khai01 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 6,644
