Salta al contenuto principale
Instant Pot IP-DUO80 V2 Sealing Ring Replacement
Cosa ti serve
  1. Instant Pot IP-DUO80 V2 Sealing Ring Replacement, Sealing Ring: passo 1, immagine 1 di 2 Instant Pot IP-DUO80 V2 Sealing Ring Replacement, Sealing Ring: passo 1, immagine 2 di 2
    • Remove the lid of the Instant Pot by twisting it counter-clockwise.
    • Flip the lid upside down.
  2. Instant Pot IP-DUO80 V2 Sealing Ring Replacement: passo 2, immagine 1 di 3 Instant Pot IP-DUO80 V2 Sealing Ring Replacement: passo 2, immagine 2 di 3 Instant Pot IP-DUO80 V2 Sealing Ring Replacement: passo 2, immagine 3 di 3
    • Push the bottom of the sealing ring in and up to detach one section of it from the metal ring.
    • Put your finger between the loosened sealing ring and the metal ring and slide your finger around the circumference of the lid to fully release the ring.
    • During reassembly, push one section of sealing ring down and around the metal ring (concave side of sealing ring facing metal ring) and continue with same motion around the whole ring.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S18-G2, Livingston Winter 2018 Membro di Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,626
