Salta al contenuto principale
Instant Pot IP-DUO80 V2 Float Valve Replacement
Cosa ti serve
  1. Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: passo 1, immagine 1 di 3 Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: passo 1, immagine 2 di 3 Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: passo 1, immagine 3 di 3
    • Remove the lid by twisting it counter-clockwise.
  2. Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 2, immagine 1 di 1
    • Place the lid upside down on a stable surface.
  3. Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 3, immagine 1 di 3 Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 3, immagine 2 di 3 Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 3, immagine 3 di 3
    • Remove the white rubber cover from the red float valve by pulling it off gently.
    • The red float valve will fall once the white cover is removed.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S18-G2, Livingston Winter 2018 Membro di Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Membri
12 Guide realizzate
3 Commenti
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
Harry Ethington - Replica
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
ixbah aries - Replica
How do you remove the house that the pin goes into? Mine has corrosion on the pin and inside that housing.
Resist - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 70
Tutti i Tempi: 5,595
