Salta al contenuto principale
Installing a Tow Hitch on a 2013 RAV4
Cosa ti serve
  1. Installing a Tow Hitch on a 2013 RAV4, Installing a Tow Hitch on a 2013 RAV4: passo 1, immagine 1 di 1
    • The Curt 56166 T-connector wiring kit comes everything I needed for this installation.
  2. Installing a Tow Hitch on a 2013 RAV4: passo 2, immagine 1 di 1
    • Remove the cargo area cover – emptying all the ‘junk’ and spare tire. The rear scuff panel and cargo tray on the driver’s side are removed by popping the plastic rivets and metal bolts.
    • On both black side panels, there are two 12mm bolts near the top and a 10 mm bolt on the rear post. There is cargo ring bolt at the bottom; it can be removed for more access, but it's not necessary.
    • With the JBL speaker on the driver’s side, it made accessing the wiring a bit tougher. (NOTE: The picture that came with the instructions shows the harness being accessed by removing the small vented panels. This is not accurate. The harness is located up higher and behind the rear trim.)
  3. Installing a Tow Hitch on a 2013 RAV4: passo 5, immagine 1 di 1
    • Above the side panels are the rear trim panels that the plastic tools can be pried with one of the plastic tools. The top plastic rivets are tough and may slip out of the panels, but you can pop them out and slide them back on to the panel. Once those are free, you can see the light harnesses on both sides.
  4. Installing a Tow Hitch on a 2013 RAV4: passo 6, immagine 1 di 1
    • I used a piece of wood to brace the panels open, rather than removing them entirely:
  5. Installing a Tow Hitch on a 2013 RAV4: passo 7, immagine 1 di 1
    • Once the side panel is free, you can see the lighting harness. Do the same on the passenger side. (NOTE: The picture that came with the wiring instructions shows the harness being accessed by removing the small vented panels. This is not accurate. The harness is located up higher and behind the rear trim.)
  6. Installing a Tow Hitch on a 2013 RAV4: passo 8, immagine 1 di 1
    • The harness on the driver’s side can be separated by pressing the small tab (next step) and reconnected to the red/yellow/brown t-connector coming from the converter.
  7. Installing a Tow Hitch on a 2013 RAV4: passo 9, immagine 1 di 1
    • The harness has snap connectors which come apart by pressing down on the small, thin 'handles' on the inserted part.
  8. Installing a Tow Hitch on a 2013 RAV4: passo 10, immagine 1 di 1
    • A black 12g wire which will connect the converter box to the battery comes with the kit. Attach wire to the black wire on the converter box with one of the straight connectors.
  9. Installing a Tow Hitch on a 2013 RAV4: passo 11, immagine 1 di 1
    • The converter box can be attached to the rear post with the 2-sided tape that came with the kit. By removing one of the bolts of the speaker assembly, the grounding wire can be slid between the assembly and frame and the bolt re-inserted to provide a ground. (If no speaker, a hole exists to insert a hex head bolt)
  10. Installing a Tow Hitch on a 2013 RAV4: passo 12, immagine 1 di 2 Installing a Tow Hitch on a 2013 RAV4: passo 12, immagine 2 di 2
    • The green wire to the passenger side harness can be run under the top panel which can be pried open slightly along the rubber seal. Run the wire down inside the side panel. Attach to T-connector to the wiring harness.
  11. Installing a Tow Hitch on a 2013 RAV4: passo 13, immagine 1 di 1
    • Looking from the underside of the rear metal bumper assembly, I found a rectangular rubber insert which can be removed. The connector to the trailer hitch and wire to the battery can exit the hatch area without any drilling of holes or removing the rubber plugs from the cargo pit. Thread both wires down and through the post connecting the bumper.
    • I ran the black 12 gauge wire to the battery under the car. Avoid running it through the springs and main moving parts that are part of the wheel and suspension system. There are two plastic covers that the wire can slip in to for support. Tie downs can be attached after testing.
    • NOTE: some people run the cable inside the car and through a grommet fitting under the glove box. However, the wire supplied with the kit may not be long enough and the purchase of one that is will be required.
  12. Installing a Tow Hitch on a 2013 RAV4: passo 16, immagine 1 di 1
    • Once in the engine compartment, remove the negative terminal. Attach one of the red fuse link wires to the 12g wire with the remaining straight connector and the other part of the fuse link to the battery positive side using the round connector. Insert the fuse. Re-attach the negative terminal and check with trailer wire tester.
    • Use the black tie-downs to secure the 12g wire to the vehicle frame. Avoid attaching it to any of the moving parts like the suspension springs, etc..
  13. Installing a Tow Hitch on a 2013 RAV4: passo 18, immagine 1 di 1
    • The Curt hitch 13149 comes with 4 bolts that fit into the pre-drilled holes on the frame.
  14. Installing a Tow Hitch on a 2013 RAV4: passo 19, immagine 1 di 2 Installing a Tow Hitch on a 2013 RAV4: passo 19, immagine 2 di 2
    • With wiring complete, installing the hitch first required removing the muffler from the rear exhaust isolator, a rubber bracket holding the metal peg attached to the muffler. Some people find this step unnecessary, but working alone, doing this made the installation easier.
  15. Installing a Tow Hitch on a 2013 RAV4: passo 20, immagine 1 di 1
    • The driver's side has a hidden hitch bracket which needs to be unbolted from the frame before the hitch can be attached. One of those holes will be used and another uncovered to attach that side of the hitch.
    • There is a metal 'Y' bolted to the top of the muffler that prevents it from swaying into the gas tank. If after installing the hitch, you hear it rattling against the hitch, try removing the two hex bolts and reversing it.
    • With the muffler free, it was easier to access the passenger side frame where pre-drilled holes existed. They are covered by a thin piece of material which can be scrapped off. I applied some grease to the hitch bolts before inserting and torquing them to 86 foot pounds.
    • Back to the driver's side, I used the supplied bolts, greasing them and torquing as on the passenger side.
Conclusione
Accessing and installing the wiring is the most difficult part of this project, so it will take the longest to do. The small cost of the plastic tool kit is worth the investment to reduce damaging the vinyl and plastic interior parts. The advantage of this IFIXIT project is that you have access to your vehicle throughout in case you need it.
Altre 3 persone hanno completato questa guida.
wrobbin3
Membro da: 12/31/12
211 Reputazione
1 Guida realizzata
2 Commenti
Our full-service NYC towing company gives busy drivers the help that they need when they need it so they can get back to work and back on schedule fast.
linda - Replica
I sincerely appreciate your assistance on my achievement on such subject. I sincerely appreciate the information you provided regarding my areas for improvement; this knowledge will help me much in how I tackle our upcoming assignment. I appreciate your advice, and I'm hoping we can soon discover additional chances for input.
by towingkey
Mitchel mark - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 58
Tutti i Tempi: 11,839
