Salta al contenuto principale
iMac Intel 24" EMC 2267 RAM Replacement
Cosa ti serve
  1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: passo 1, immagine 1 di 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw PH#2 in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: passo 2, immagine 1 di 2 iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: passo 2, immagine 2 di 2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 24" EMC 2267 RAM Replacement: passo 3, immagine 1 di 1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
Conclusione
Altre 35 persone hanno completato questa guida.
johann beda
Membro da: 09/13/10
2.483 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 45
Tutti i Tempi: 25,863
