Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Guide created by KimJongIan
With help by iFixit users Andrew and MervDervis
This guide would not be possible without the script made by user tai1976 from gbatemp.net
  1. Before doing any updates or software changes with the Hard Drive connected to the motherboard, make sure that all connections  to the board are secure, such as the disc drive, otherwise you will brick the Motherboard, and will require a new one.
    • Before doing any updates or software changes with the Hard Drive connected to the motherboard, make sure that all connections to the board are secure, such as the disc drive, otherwise you will brick the Motherboard, and will require a new one.
    Updating the console without the optical drive in place will brick the console? Are we certain about this? I know that the motherboard and optical drive board are paired but didn't think that the console would brick if updated without the drive plugged in. Thanks for the help - Richard
    Richard - Replica
  2. Before beginning this guide, it is best to read through the steps for the hardware portion, as shown by iFixit user Andrew, at the following link.
    • Before beginning this guide, it is best to read through the steps for the hardware portion, as shown by iFixit user Andrew, at the following link.
    • Xbox One S Hard Drive Replacement
    • You will also need a PC running Windows, and a hard drive reader (Sata Data and Sata Power to USB)
    • Seagate drives have been known to cause issues with XBox One software.
    The original drive in the Xbox is a Seagate drive. The support forum for the script also does not mention this at all.
    gogocons - Replica
    Seagate drives have been known to cause issues with XBox One software. << what you mean by that … not to by any seagate driver?
    doscarri - Replica
    which hard disk do you recommend
    drkanu198300 - Replica
  3. Connect the new hard drive to the PC. Make sure that the HDD is in a location where it will not be accidentally disconnected.
    • Connect the new hard drive to the PC. Make sure that the HDD is in a location where it will not be accidentally disconnected.
  4. This process requires you to run a script to partition the HDD/SSD.
    filetrip.net is now closed, can’t download file
    Sccoaire - Replica
  5. Press the Windows key/Start menu and type in &quot;CMD&quot;, right click, and select 'Run as Administrator&quot;
    • Press the Windows key/Start menu and type in "CMD", right click, and select 'Run as Administrator"
    • Type the command "cd C:\Users\(Your Name)\Downloads\xboxonehdd-master-6.1\xboxonehdd-master\win"
    • Replace (Your name) with the name of your user profile.
  6. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  7. Run the command &quot;create_xbox_drive&quot;
    • Run the command "create_xbox_drive"
    • The next steps are to create a drive that has either 500GB, 1TB, or 2TB storage. If at anytime you get confused, there is a readme file in the folder you extracted that can help out as well.
    I have a 480 gig ssd. Can this be used with your script?
    Paul - Replica
  8. For this tutorial, we are using the first option (a) Replace/Upgrade w/o a working original drive. For this tutorial, we are using the first option (a) Replace/Upgrade w/o a working original drive.
    • For this tutorial, we are using the first option (a) Replace/Upgrade w/o a working original drive.
  9. Make sure to choose the right drive to format, Disk 0 is almost always your operating system, DO NOT CHOOSE DISK 0. It will ask you to confirm your selection. Then you will need to choose the size of the drive you have created.
    • Make sure to choose the right drive to format, Disk 0 is almost always your operating system, DO NOT CHOOSE DISK 0.
    • It will ask you to confirm your selection.
    • Then you will need to choose the size of the drive you have created.
    What if Disk 0 is your only option?!
    Emily Clark - Replica
    So the computer we are using isn’t even recognizing the drive as being connected. The drive makes noise and lights come on the connector we have but the computer can’t find it. I have no idea what is wrong or how to fix this.
    We figured it out! For anyone else struggling, We ended up having to plug in the USB in the BACK of the computer instead of the front ports. It connected immediately and it’s been a success since (haven’t actually tried it in the xbox yet though)
  10. Once the command line displays 6 lines of long numbers with &quot;GUID&quot; at the top, the command lines is finished.
    • Once the command line displays 6 lines of long numbers with "GUID" at the top, the command lines is finished.
    • If this doesn't work, clean the disk with diskpart, link below, and try again.
    • http://knowledge.seagate.com/articles/en...
    i am getting a message saying Missing Drive x: System update.
    i have reformatted the drive and cleaned the ssd with diskpart. but still get the same message.
    Jonathan Murnion - Replica
  11. You need to go to the XBox official site and download a file called OSU 1. https://support.xbox.com/en-US/xbox-one/... Select &quot;I need to update my console offline&quot;
    • You need to go to the XBox official site and download a file called OSU 1.
    • https://support.xbox.com/en-US/xbox-one/...
    • Select "I need to update my console offline"
    • Select "Xbox One S or Xbox One X"
    • Click the green link "OSU1" to start the download.
  12. Navigate to the System Update (X) drive, and create 2 folders, one labeled &quot;A&quot; and one &quot;B&quot; Extract all of the files from OSU1, and copy everything in $SystemUpdate, except for &quot;updater.xvd&quot; Paste these files in the folders &quot;A&quot; and &quot;B&quot; that you created.
    • Navigate to the System Update (X) drive, and create 2 folders, one labeled "A" and one "B"
    • Extract all of the files from OSU1, and copy everything in $SystemUpdate, except for "updater.xvd"
    • Paste these files in the folders "A" and "B" that you created.
    • Copy "updater.xvd" from $SystemUpdate and paste it in the root of System Update (X)
    • Note that you will need to download the bootanim.dat and store it in folders "A" and "B" as well. There are two different versions you can download one for OG / S or the X. Without the file the Xbox will boot with a black screen to the menu and not the boot logo.
    Where is system update x
    It is created when formatting the new drive in command prompt using the steps above.
    Dale Peters - Replica
    Hello,
    Thank you for the write up as it was very helpful. there are some updated steps needed though. Especially if getting error code E102 and E101. Follow this video ararting at 14:10. https://youtu.be/J1xX6WgJhVA
    Basically I followed your steps and kept failing to load HHD. To find out needed to add the boot animation needing to be added to both A and B filter along with just copy the updater.xvd to the main folder not delete from A and B folder. I still got the E106 error but that's expected. Then next step after restart from E106 error required offline update using OSU1 offline system update from Xbox.
    https://support.xbox.com/help/hardware-n...
    Hope that helps.
    Jeff Brown - Replica
    Where is the bootanim.dat file?
    uBreakiFix Woodbridge ON - Replica
    grazie ifixit seguito passo passo le vostre istruzione funziona al 100%
    xbox one S hdd 500 gb
    grazie e ciaoooooo
    saxon - Replica
  13. Safely eject the media and put it back into the XBox
  14. Some users have experienced sign in issues after an ssd upgrade. If this occurs, simply reset the console (keep games and apps if need be.) and that should resolve the issue.
    • Some users have experienced sign in issues after an ssd upgrade. If this occurs, simply reset the console (keep games and apps if need be.) and that should resolve the issue.
    • Those who have their Xbox set to "energy saving" mode for startup may experience a 20-30 second black screen before boot. Changing this setting to "instant on" resolves this issue.
    • Now enjoy 20x faster r/w speeds and loading times a fraction that of a standard HDD.
  15. You are now finished, enjoy your XBox!
    • You are now finished, enjoy your XBox!
    • Note: This does work with Solid State Drives.
Conclusione
To reassemble your device, put the hard drive back in the Xbox One S and reassemble.
Altre 25 persone hanno completato questa guida.
KimJongIan
Membro da: 27/04/2018
998 Reputazione
1 Guida realizzata
It doesn’t work for me. Always “No USB/SATA drives found”. All drives are “online”.
Dennis Becker - Replica
I have the same problem, I can’t decide what to do?
Диск ### Состояние Размер Свободно Дин GPT
Диск 0 В сети 1863 Gбайт 0 байт
Диск 1 В сети 3726 Gбайт 0 байт *
Диск 2 В сети 1863 Gбайт 0 байт
Диск 3 В сети 1863 Gбайт 1863 Gбайт
Диск 4 В сети 223 Gбайт 2048 Kбайт
Диск 5 Нет носителя 0 байт 0 байт
* No USB/SATA drives found *
* Script execution complete.
eshkinin.s -
Works perfect, back up and running… thanks!
dvmath50 - Replica
Doesn't work with soild state drives? Isn't that what's in there to begin with?
Rob Hartwig - Replica
This does work with solid state drives, it doesn’t work, occasionally, with seagate drives.
KimJongIan -
Any reason why we can’t just use Acronis True Image to make a 1:1 copy of the original drive?
Blair Skinner - Replica
This guide is more for replacing a failed drive, so if you are upgrading the drive, then cloning it and resizing partitions is the way to go.
KimJongIan -
Which files go in “A” and which ones go in “B”
grady respess - Replica
i purchased a replacement hard drive from you and it is a seagate !!!!! does not work
Jason Csencsits - Replica
I have a black screen for 20 seconds when starting up. After that I land on the start screen. the quickstart is off. The black screen is also there.
Florian Hunger - Replica
Все работает. Спасибо! Копировал на Crucial MX 500 2TB SSD.
Владимир Рудковский - Replica
this method does not work! please remove this page. thanks.
capthook - Replica
Does this also apply to the Xbox One X?
Ben - Replica
Great guide. works perfect ! great job !
stavru doru-sorin - Replica
Cant i start the xbox in safe mode then update it cause i have the OSU file on a USB
Brennan Beattie - Replica
the master files can not be got there is no response from file trip
jason.redfern - Replica
Guy, Thanks for this post, but you know if this procedure works for Xbox One X?
mritto - Replica
i can not get this to work after running the script adn selecting the drive size i wait for 30 seconds and just get a message saying Missing drive X ‘System Update’ anyone seen this or know how to fix it?
Were you able to figure this out? Getting the same issue.. :(
teejays -
Does this change MAC / Console Id / Xbox Live Device ID?
Shin Godzilla - Replica
This work excelent! I was changed my damaged hard drive for one new, and that’s works and the first time.
Note: For windowos 7 must be use “create_xbox_drive_old”.
Thanks for this guide!
delgado_sntgo - Replica
I’ve done everything like in the tutorial, but in the end I get Error E106. My Console is a Xbox One S, and I am trying to install a mechanical HDD. I’ve erased alleready the original HDD that came with the xbox.
Also I’ve tried installing the OSU 1 files on a flash drive, and selected the option from the troubleshooter to “install offline update” and it diden’t work. what should I do ?
festy22 - Replica
Hey there! I’m turning xbox one on for update process and after 5% it shuts down. Can you help me with this problem?
NGA - Replica
I'm getting the same thing
erika -
i tried this tutorial in 2 consoles but always shows me the same problem.
I tried with 2 or 3 Hard disk and with 2 xbox One S but i can not.
In the morning 2 xbox have been working good but i need to change one motherboard in one of them. please help. greetings
gelodiaz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 169
Ultimi 7 Giorni: 1,044
Ultimi 30 Giorni: 4,636
Tutti i Tempi: 61,446
