Salta al contenuto principale
Install an Extension Cord Female Plug
Cosa ti serve
  1. Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: passo 1, immagine 1 di 3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: passo 1, immagine 2 di 3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: passo 1, immagine 3 di 3
    • Install an Extension Cord Female Plug is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut from the middle and around the cable.
    Chiedi a FixBot
    Aggiungi Commento
  2. Install an Extension Cord Female Plug: passo 2, immagine 1 di 3 Install an Extension Cord Female Plug: passo 2, immagine 2 di 3 Install an Extension Cord Female Plug: passo 2, immagine 3 di 3
    • Use wire strippers to remove about 2 cm from the inner wires
    Chiedi a FixBot
    Aggiungi Commento
  3. Install an Extension Cord Female Plug: passo 3, immagine 1 di 2 Install an Extension Cord Female Plug: passo 3, immagine 2 di 2
    • Make sure you put the bottom cover of the female plug.
    Chiedi a FixBot
    Aggiungi Commento
  4. Install an Extension Cord Female Plug: passo 4, immagine 1 di 3 Install an Extension Cord Female Plug: passo 4, immagine 2 di 3 Install an Extension Cord Female Plug: passo 4, immagine 3 di 3
    • The green screw is for the (green wire), the gold screw is for the (black wire), and the silver screw is for the (white wire).
    • For green wire.
    • For black wire
    • For white wire.
    • Now when you have each wire inside the hole you tighten the three screws.
    Chiedi a FixBot
    Aggiungi Commento
  5. Install an Extension Cord Female Plug: passo 5, immagine 1 di 3 Install an Extension Cord Female Plug: passo 5, immagine 2 di 3 Install an Extension Cord Female Plug: passo 5, immagine 3 di 3
    • Electrical tape is optional.
    • Need to make sure both of the parts are lined up in the same directions.
    • Push both parts together and you would see the screws pop up.
    Chiedi a FixBot
    Aggiungi Commento
  6. Install an Extension Cord Female Plug: passo 6, immagine 1 di 3 Install an Extension Cord Female Plug: passo 6, immagine 2 di 3 Install an Extension Cord Female Plug: passo 6, immagine 3 di 3
    • Tightening the top three screws.
    • Also, need to tighten the two bottom screws.
    • Make sure you have one or two fingers in the back of the two screws so they pop up.
    Chiedi a FixBot
    Aggiungi Commento
  7. Install an Extension Cord Female Plug: passo 7, immagine 1 di 1
    • Test out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
CSU Los Angeles, Team 5-20, Kershman Fall 2023 Membro di CSU Los Angeles, Team 5-20, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G20
Membro di 1
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 43
Ultimi 30 giorni: 199
Tutti i Tempi: 2,102
