Salta al contenuto principale
Install Ubuntu 16 on the Pixel
  1. Install Ubuntu 16 on the Pixel, Enable stuff!: passo 1, immagine 1 di 2 Install Ubuntu 16 on the Pixel, Enable stuff!: passo 1, immagine 2 di 2
    • Enable Developer Mode/Legacy Boot
    • As mentioned before, you don't need to flash your BIOS, we'll just use the stock SeaBIOS.
    • This means you'll have to press "crtl" + "L" on each boot
    • It'll take some time so grab a coffee while you're waiting...
  2. Install Ubuntu 16 on the Pixel, Boot up Ubuntu: passo 2, immagine 1 di 1
    • Unlike the Windows installation, you don't need a USB keyboard or mouse to boot the OS
    • Select your USB installer drive on startup
    • You should get the Ubuntu startup screen
  3. Install Ubuntu 16 on the Pixel: passo 3, immagine 1 di 2 Install Ubuntu 16 on the Pixel: passo 3, immagine 2 di 2
    • I highly recommend you connect to Wi-Fi before you continue to get all the necessary drivers
    • The Wi-Fi card is automatically detected on boot
    • Just step through the installer like you would with any other distro
  4. Install Ubuntu 16 on the Pixel, Reboot: passo 4, immagine 1 di 1
    • Remove your installation media and reboot when prompted by Ubuntu
    • On startup, login to your account and setup your hotkeys to enable volume (mute, decrease, increase).
    • Display brightness can be fixed by setting up a custom keymapping:
    • sudo apt-get install xdotool
    • name: Brightness Up command: xdotool key XF86MonBrightnessUp
    • name: Brightness Down command: xdotool key XF86MonBrightnessDown
Conclusione
You're done! If you ever want to get back to ChromeOS just create a recovery drive in your Chrome browser and enable secure boot at the Pixel startup.
Kevin Fessler
Membro da: 04/16/16
1.770 Reputazione
4 Guide realizzate
Un commento
Trying to do the brightness key map .I did this sudo apt-get install xdotool.What do I do next i cant seem to find the app xdotool ?
wesley tejeda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,499
