Guida fornita dalla comunitĂ
Un fantastico membro della nostra community ha creato questa guida. Non è stata creata dallo staff di iFixit.
Introduzione
Vai al passo 1 ↓This LED Switchback side markers is a direct replacement for your OEM side markers to make your Porsche Cayenne be unique.
Cosa ti serve
Ricambi
Turn the wheel inside
Remove the clips in the wheelbase to access the back of the side marker.
You can see that the installation process is very straightforward. Your Porsche Cayenne is now extremely unique on the road with these switchback LED side marker lights!
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
can you tell us where you connected the white wire? it doesn’t show in the images. did you just tap the DRL wire nearby or run it to the fuse box?
There si an easier way to remove the lights - take apiece of fishing line and wrap it over the front and behind the light. Pull it towards the door and it will release the front catch and the light pops right out
