Salta al contenuto principale
Inspiron 7359 2-in-1 Fan Replacement
Cosa ti serve
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: passo 1, immagine 1 di 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: passo 2, immagine 1 di 2 Inspiron 7359 2-in-1 Fan Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: passo 3, immagine 1 di 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: passo 4, immagine 1 di 1
    • All hardware components should be exposed.
  5. Attenzione: i passaggi 5-6 provengono da una guida contrassegnata come in corso.
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: passo 5, immagine 1 di 1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: passo 6, immagine 1 di 2 Inspiron 7359 2-in-1 Fan Replacement: passo 6, immagine 2 di 2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: passo 7, immagine 1 di 2 Inspiron 7359 2-in-1 Fan Replacement, Fan: passo 7, immagine 2 di 2
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: passo 8, immagine 1 di 1
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: passo 9, immagine 1 di 1
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Conclusione
Dominique
Membro da: 08/26/19
251 Reputazione
2 Guide realizzate
Gateway, Team S1-G3, Saknee Fall 2019 Membro di Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 449
