Salta al contenuto principale
Insignia Sport NS-4V17 Front Case Cover Replacement
Cosa ti serve
  1. Insignia Sport NS-4V17 Front Case Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Front Case Cover Replacement: passo 2, immagine 1 di 2 Insignia Sport NS-4V17 Front Case Cover Replacement: passo 2, immagine 2 di 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Front Case Cover Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Front Case Cover Replacement: passo 4, immagine 1 di 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: passo 5, immagine 1 di 2 Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: passo 5, immagine 2 di 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Front Case Cover Replacement: passo 6, immagine 1 di 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Front Case Cover Replacement: passo 7, immagine 1 di 3 Insignia Sport NS-4V17 Front Case Cover Replacement: passo 7, immagine 2 di 3 Insignia Sport NS-4V17 Front Case Cover Replacement: passo 7, immagine 3 di 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Front Case Cover Replacement: passo 8, immagine 1 di 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Conclusione
Cal Poly, Team 12-36, Amido Spring 2013 Membro di Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 369
