Salta al contenuto principale
Insignia NS-VCS14SL7 Stick Vacuum Power Button Replacement
Cosa ti serve
  1. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: passo 1, immagine 1 di 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: passo 1, immagine 2 di 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: passo 1, immagine 3 di 3
    • Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
    • Pull up on the back cover of the vacuum handle and remove it.
  2. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: passo 2, immagine 1 di 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: passo 2, immagine 2 di 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: passo 2, immagine 3 di 3
    • Remove the two 10mm Phillips #2 screws on the back of the green printed circuit board.
    • If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
Conclusione
Thibaut Pillot
Membro da: 02/15/18
434 Reputazione
5 Guide realizzate
USF Tampa, Team S16-G3, Boczar Spring 2018 Membro di USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 178
