Introduzione
Removing the back of the fan cage provides access to the motor housing.
Cosa ti serve
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
Altre 3 persone hanno completato questa guida.
