Salta al contenuto principale
Insignia NS-F12R6-SS Fan Blade Replacement
Cosa ti serve
  1. Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: passo 1, immagine 1 di 2 Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: passo 1, immagine 2 di 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Fan Blade Replacement: passo 2, immagine 1 di 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Fan Blade Replacement: passo 3, immagine 1 di 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Fan Blade Replacement, Fan Blade: passo 4, immagine 1 di 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Fan Blade Replacement: passo 5, immagine 1 di 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
Conclusione
Hank
Membro da: 09/17/18
1.142 Reputazione
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 389
