Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
In this tutorial the user will be able to replace the disc tray on their Insignia NS-DS9PDVD15.
Parti
Nessuna parte specificata.
  1. Turn the power off. Slide the power button to OFF. Turn the power off. Slide the power button to OFF.
    • Turn the power off. Slide the power button to OFF.
  2. Unplug AC adapter from car cigarette lighter. Unplug AC adapter from car cigarette lighter.
    • Unplug AC adapter from car cigarette lighter.
  3. Make sure there is no DVD or CD in the disc tray
    • Make sure there is no DVD or CD in the disc tray
  4. Unscrew the nine 9mm screws with a JIS #000 screwdriver. Unscrew the nine 9mm screws with a JIS #000 screwdriver.
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Pry off back panel with prying tool, then remove by hand. Pry off back panel with prying tool, then remove by hand. Pry off back panel with prying tool, then remove by hand.
    • Pry off back panel with prying tool, then remove by hand.
  6. After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge. Unscrew them with the JIS #000 screwdriver.
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Slide the tray up and off of the hinge completely.
    • Slide the tray up and off of the hinge completely.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 65
