Parti
Nessuna parte richiesta.
  1. Turn the power off. Slide the power button to OFF. Turn the power off. Slide the power button to OFF.
    • Turn the power off. Slide the power button to OFF.
  2. Unplug AC adapter from car cigarette lighter. Unplug AC adapter from car cigarette lighter.
    • Unplug AC adapter from car cigarette lighter.
  3. Make sure there is no DVD or CD in the disc tray
    • Make sure there is no DVD or CD in the disc tray
  4. Unscrew the nine 9mm screws with a JIS #000 screwdriver. Unscrew the nine 9mm screws with a JIS #000 screwdriver.
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Pry off back panel with prying tool, then remove by hand. Pry off back panel with prying tool, then remove by hand. Pry off back panel with prying tool, then remove by hand.
    • Pry off back panel with prying tool, then remove by hand.
  7. After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge. Unscrew them with the JIS #000 screwdriver.
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  8. Slide the tray up and off of the hinge completely.
    • Slide the tray up and off of the hinge completely.
  9. Locate the disk reader, it  will be right under the disk chamber.
    • Locate the disk reader, it will be right under the disk chamber.
  10. Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
    • Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
  11. Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
    • Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 186
