Salta al contenuto principale
Insignia NS-CLOPP2 Speaker Replacement
Cosa ti serve
  1. Insignia NS-CLOPP2 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the screws from the back panel using a Phillips #00 screwdriver.
    • Gently pull to remove the motherboard.
    • Do not cut any wires when removing the motherboard
  2. Insignia NS-CLOPP2 Speaker Replacement: passo 2, immagine 1 di 2 Insignia NS-CLOPP2 Speaker Replacement: passo 2, immagine 2 di 2
    • Scrape off the glue using an opening tool to detach the speaker from the black clock.
  3. Insignia NS-CLOPP2 Speaker Replacement: passo 3, immagine 1 di 1
    • After removing the adhesive, carefully remove the speaker from the device.
    • Use a technology-friendly adhesive to reinstall the new speaker.
Linea Traguardo
Marist, Team 1-1, Laflen Spring 2015 Membro di Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 269
