Salta al contenuto principale
Insignia NS-CLOPP2 Motherboard Replacement
Cosa ti serve
  1. Insignia NS-CLOPP2 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • First, remove the front screen. (See prerequisite screen removal guide.)
  2. Insignia NS-CLOPP2 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
  3. Insignia NS-CLOPP2 Motherboard Replacement: passo 3, immagine 1 di 1
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
  4. Insignia NS-CLOPP2 Motherboard Replacement: passo 4, immagine 1 di 1
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    • To reassemble your device, follow these instructions in reverse order.
Conclusione
Altre 3 persone hanno completato questa guida.
Marist, Team 1-1, Laflen Spring 2015 Membro di Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 126
