Introduzione
If your iPhone dock is broken, or your iPhone is not connecting to the dock, you might need to replace the Apple lightning connector, which connects directly to your iPhone on one end, and to an internal circuit board on the other. You may want to use a magnetic project mat during this process to keep track of and organize the several small screws you will be working with.
Cosa ti serve
Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
