Salta al contenuto principale
Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement
Cosa ti serve
  1. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement, Power Auxiliary Port Replacement: passo 1, immagine 1 di 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 2, immagine 1 di 1
    • Peel back the adhesive sticker using a metal spudger and remove the 11mm screw beneath the sticker with a Phillips head screw driver.
  3. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 3, immagine 1 di 1
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 4, immagine 1 di 1
    • Unscrew the six 11mm screws with a Phillips head screw driver.
  5. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 5, immagine 1 di 1
    • Remove the bottom of the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 6, immagine 1 di 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 7, immagine 1 di 1
    • Lift the motherboard from the device and lie it face down. Beware of the cables plugged in on the back side
  8. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 8, immagine 1 di 1
    • Remove the plug to your left.
  9. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 9, immagine 1 di 1
    • Remove the plug to your right from the motherboard.
  10. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 10, immagine 1 di 1
    • Remove the plug in the front of the lcd screen plug.
  11. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: passo 11, immagine 1 di 1
    • Remove the LCD screen plug last. For reassembly, follow the instructions in reverse order, replacing the old motherboard with the new one to fix the power auxiliary port.
Conclusione
Erik
Membro da: 02/19/15
405 Reputazione
4 Guide realizzate
USF Tampa, Team 9-3, Leahy Winter 2015 Membro di USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 202
