Salta al contenuto principale
Insignia NS-CLIP02 Keypad Replacement
Cosa ti serve
  1. Insignia NS-CLIP02 Keypad Replacement, Keypad: passo 1, immagine 1 di 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Keypad Replacement: passo 2, immagine 1 di 1
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Insignia NS-CLIP02 Keypad Replacement: passo 3, immagine 1 di 1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 Keypad Replacement: passo 4, immagine 1 di 1
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 Keypad Replacement: passo 5, immagine 1 di 1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 Keypad Replacement: passo 6, immagine 1 di 1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Keypad Replacement: passo 7, immagine 1 di 1
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 Keypad Replacement: passo 8, immagine 1 di 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 Keypad Replacement: passo 9, immagine 1 di 1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 Keypad Replacement: passo 10, immagine 1 di 1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 Keypad Replacement: passo 11, immagine 1 di 1
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 Keypad Replacement: passo 12, immagine 1 di 1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 Keypad Replacement: passo 13, immagine 1 di 1
    • Remove the plug in the front of the lcd screen plug.
  14. Insignia NS-CLIP02 Keypad Replacement: passo 14, immagine 1 di 1
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the keypad.
Conclusione
Erik
Membro da: 02/19/15
405 Reputazione
4 Guide realizzate
USF Tampa, Team 9-3, Leahy Winter 2015 Membro di USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 137
