Salta al contenuto principale
Insignia NS-CLIP02 Digital Display Replacement
Cosa ti serve
  1. Insignia NS-CLIP02 Digital Display Replacement, Motherboard: passo 1, immagine 1 di 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Digital Display Replacement: passo 2, immagine 1 di 2 Insignia NS-CLIP02 Digital Display Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Digital Display Replacement: passo 3, immagine 1 di 2 Insignia NS-CLIP02 Digital Display Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Digital Display Replacement: passo 4, immagine 1 di 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Digital Display Replacement: passo 5, immagine 1 di 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Digital Display Replacement: passo 6, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Digital Display Replacement: passo 7, immagine 1 di 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Digital Display Replacement: passo 8, immagine 1 di 3 Insignia NS-CLIP02 Digital Display Replacement: passo 8, immagine 2 di 3 Insignia NS-CLIP02 Digital Display Replacement: passo 8, immagine 3 di 3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Digital Display Replacement, Digital Display: passo 9, immagine 1 di 1
    • Using the Phillips screwdriver, remove the three screws that run along the center of the base.
  10. Insignia NS-CLIP02 Digital Display Replacement: passo 10, immagine 1 di 2 Insignia NS-CLIP02 Digital Display Replacement: passo 10, immagine 2 di 2
    • Carefully remove the base.
  11. Insignia NS-CLIP02 Digital Display Replacement: passo 11, immagine 1 di 2 Insignia NS-CLIP02 Digital Display Replacement: passo 11, immagine 2 di 2
    • Using the metal spudger, gently lift the face plate away from the display.
  12. Insignia NS-CLIP02 Digital Display Replacement: passo 12, immagine 1 di 1
    • Once the face plate is removed, use the Phillips screwdriver to remove the six screws shown here.
  13. Insignia NS-CLIP02 Digital Display Replacement: passo 13, immagine 1 di 2 Insignia NS-CLIP02 Digital Display Replacement: passo 13, immagine 2 di 2
    • Using the metal spudger, lift the speaker grilles from the display.
    • The speaker grilles will hinge on the side closest to the display.
  14. Insignia NS-CLIP02 Digital Display Replacement: passo 14, immagine 1 di 1
    • Using the Phillips screwdriver, remove the four screws shown here.
  15. Insignia NS-CLIP02 Digital Display Replacement: passo 15, immagine 1 di 2 Insignia NS-CLIP02 Digital Display Replacement: passo 15, immagine 2 di 2
    • The two pieces of the display should easily separate.
  16. Insignia NS-CLIP02 Digital Display Replacement: passo 16, immagine 1 di 1
    • Using the Phillips screwdriver, remove the three screws shown here.
  17. Insignia NS-CLIP02 Digital Display Replacement: passo 17, immagine 1 di 3 Insignia NS-CLIP02 Digital Display Replacement: passo 17, immagine 2 di 3 Insignia NS-CLIP02 Digital Display Replacement: passo 17, immagine 3 di 3
    • The digital display should now be easy to remove.
    • Replace with new part.
Conclusione
Aubrey
Membro da: 02/24/15
214 Reputazione
2 Guide realizzate
USF Tampa, Team 9-3, Leahy Winter 2015 Membro di USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 469
