Salta al contenuto principale
Insignia NS-B4111 Antenna Replacement
Cosa ti serve
  1. Insignia NS-B4111 Antenna Replacement, Battery: passo 1, immagine 1 di 2 Insignia NS-B4111 Antenna Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Antenna Replacement: passo 2, immagine 1 di 2 Insignia NS-B4111 Antenna Replacement: passo 2, immagine 2 di 2
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Antenna Replacement, External Antenna: passo 3, immagine 1 di 1
    • Set the boombox upright. Remove the 4mm screw and the two 6mm washers with the Phillips PH1 screwdriver.
    • Remove the external antenna.
  4. Insignia NS-B4111 Antenna Replacement, Casing: passo 4, immagine 1 di 1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  5. Insignia NS-B4111 Antenna Replacement: passo 5, immagine 1 di 2 Insignia NS-B4111 Antenna Replacement: passo 5, immagine 2 di 2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  6. Insignia NS-B4111 Antenna Replacement, Antenna Base: passo 6, immagine 1 di 2 Insignia NS-B4111 Antenna Replacement, Antenna Base: passo 6, immagine 2 di 2
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
Conclusione
UC Davis, Team 1-5, Oliver Fall 2016 Membro di UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 787
