Introduzione
Follow these instructions to remove and replace the transformer in your boombox. This requires some simple soldering, so make sure you have a soldering iron handy and know how to use it. An easy step-by-step guide to soldering can be found here.
Cosa ti serve
Flip the stereo so the CD opening is face down.
With two fingers, pinch the tabs and lift up to open the battery protection cover.
Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
Remove the transformer and set it to the side.
