Introduzione
Follow this guide to replace your LED display so you can navigate through your tunes easier. The wires get a little messy, so be sure you have a clean area to work in. This guide requires soldering. If you don't know how to solder, a simple step-by-step guide can be found here.
Flip the stereo so the CD opening is face down.
  • Flip the stereo so the CD opening is face down.
  • With two fingers, pinch the tabs and lift up to open the battery protection cover.
Aggiungi Commento
Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
  • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
  • Repeat until all eight batteries are removed.
  • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Aggiungi Commento
  • With a Phillips #2 screwdriver, remove two 2mm screws.
Aggiungi Commento
  • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
  • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
Aggiungi Commento
  • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
  • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
  • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
Aggiungi Commento
  • With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
  • More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
  • Remove the green quarter circle circuit board and place to the side.
Aggiungi Commento
  • On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
Aggiungi Commento
  • With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
Aggiungi Commento
  • Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
Aggiungi Commento
  • Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
  • Remove the rectangular circuit board and place it to the side.
Aggiungi Commento
  • With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
  • Remove the black plastic frame.
Aggiungi Commento
  • With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board.
  • This board has two white ribbons attached to it. Once again, be careful not to stretch these.
  • Remove and place the metal circuit board to the side.
Aggiungi Commento
  • With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
Aggiungi Commento
  • Using a Phillips #1 Screwdriver, remove the six 5mm screws from the circuit board
  • Remove the circuit board. This may require you to wiggle to board a little bit to get it free.
Aggiungi Commento
  • Remove the ten points of solder from the back of the LED display.
  • Pinch and remove the LED display from the circuit board.
Aggiungi Commento
Conclusione
Jacob Phillips
Membro da: 14/10/2013
313 Reputazione
3 Guide realizzate
Cal Poly, Team 4-31, Amido Fall 2013 Membro di Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 315
