Salta al contenuto principale
Insignia NS-B2110 Battery Replacement
Cosa ti serve
  1. Insignia NS-B2110 Battery Replacement, Battery: passo 1, immagine 1 di 2 Insignia NS-B2110 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: passo 2, immagine 1 di 2 Insignia NS-B2110 Battery Replacement: passo 2, immagine 2 di 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Conclusione
Cal Poly, Team 4-31, Amido Fall 2013 Membro di Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 349
