Introduzione
The antenna is a very important component for the radio of the Insignia NS-B2110. Antennas may snap or break, causing the radio to stop working. Removing the antenna is a fairly easy and quick fix.
Parti
Nessuna parte richiesta.
On the backside of the device, lift the plastic handle up with your hands to reveal the antenna.
  • On the backside of the device, lift the plastic handle up with your hands to reveal the antenna.
  • Lift the antenna to its upright position.
Aggiungi Commento
Remove one 6.0 mm Phillips #00 screw from the base of the antenna.
  • Remove one 6.0 mm Phillips #00 screw from the base of the antenna.
  • Remove the antenna from the metal bracket.
Aggiungi Commento
Conclusione
Daniel Hodges
Membro da: 14/10/2013
301 Reputazione
3 Guide realizzate
Cal Poly, Team 4-31, Amido Fall 2013 Membro di Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 402
