Salta al contenuto principale
Insignia NS-24ER310NA17 Motherboard Replacement
Cosa ti serve
  1. Insignia NS-24ER310NA17 Motherboard Replacement, Remove the base: passo 1, immagine 1 di 3 Insignia NS-24ER310NA17 Motherboard Replacement, Remove the base: passo 1, immagine 2 di 3 Insignia NS-24ER310NA17 Motherboard Replacement, Remove the base: passo 1, immagine 3 di 3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Motherboard Replacement: passo 2, immagine 1 di 3 Insignia NS-24ER310NA17 Motherboard Replacement: passo 2, immagine 2 di 3 Insignia NS-24ER310NA17 Motherboard Replacement: passo 2, immagine 3 di 3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Motherboard Replacement, Pry the TV open: passo 3, immagine 1 di 1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Motherboard Replacement, Disconnect wires: passo 4, immagine 1 di 3 Insignia NS-24ER310NA17 Motherboard Replacement, Disconnect wires: passo 4, immagine 2 di 3 Insignia NS-24ER310NA17 Motherboard Replacement, Disconnect wires: passo 4, immagine 3 di 3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Motherboard Replacement: passo 5, immagine 1 di 1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Remove all strips of tape attached to the silver steel rectangular piece.
  7. Insignia NS-24ER310NA17 Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull the red wire out from under the black plastic clip.
  8. Insignia NS-24ER310NA17 Motherboard Replacement: passo 8, immagine 1 di 2 Insignia NS-24ER310NA17 Motherboard Replacement: passo 8, immagine 2 di 2
    • Unscrew the four screws surrounding the steel rectangle with a Phillips 00 Screwdriver.
  9. Insignia NS-24ER310NA17 Motherboard Replacement: passo 9, immagine 1 di 1
    • Carefully lift the rectangular piece.
  10. Insignia NS-24ER310NA17 Motherboard Replacement: passo 10, immagine 1 di 1
    • The rectangular piece will still be attached to the motherboard beneath it with a strip of tape. Remove this strip of tape.
  11. Insignia NS-24ER310NA17 Motherboard Replacement: passo 11, immagine 1 di 2 Insignia NS-24ER310NA17 Motherboard Replacement: passo 11, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two screws on both sides of the motherboard.
  12. Insignia NS-24ER310NA17 Motherboard Replacement: passo 12, immagine 1 di 1
    • Carefully lift the motherboard away from the television.
    • Keep in mind that the motherboard is still attached by several thin wires and should not be tugged.
  13. Insignia NS-24ER310NA17 Motherboard Replacement: passo 13, immagine 1 di 3 Insignia NS-24ER310NA17 Motherboard Replacement: passo 13, immagine 2 di 3 Insignia NS-24ER310NA17 Motherboard Replacement: passo 13, immagine 3 di 3
    • There are 5 wires attached to the motherboard. Remove the two thicker white wires to the right of the red wire.
  14. Insignia NS-24ER310NA17 Motherboard Replacement: passo 14, immagine 1 di 3 Insignia NS-24ER310NA17 Motherboard Replacement: passo 14, immagine 2 di 3 Insignia NS-24ER310NA17 Motherboard Replacement: passo 14, immagine 3 di 3
    • Remove the remaining three wires from the mainboard.
  15. Insignia NS-24ER310NA17 Motherboard Replacement: passo 15, immagine 1 di 1
    • Carefully remove the mainboard from the television.
    • You have now successfully removed the mainboard.
Conclusione
Altre 6 persone hanno completato questa guida.
Maggie Kuntz
Membro da: 01/22/18
301 Reputazione
1 Guida realizzata
Cal Poly, Team S16-G2, Banghart Winter 2018 Membro di Cal Poly, Team S16-G2, Banghart Winter 2018
CPSU-BANGHART-W18S16G2
4 Membri
6 Guide realizzate
Un commento
Did all said including main board replace still no picture
d k - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 52
Tutti i Tempi: 11,980
