Salta al contenuto principale
Insignia NS-15MS0832B Speaker Replacement
Cosa ti serve
  1. Insignia NS-15MS0832B Speaker  Replacement, Speakers: passo 1, immagine 1 di 1
    • Begin the speaker replacement by inserting the plastic opening tool into the corner of the device.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Speaker  Replacement: passo 2, immagine 1 di 1
    • Once the backplate is separated from the screen it should look like this.
  3. Insignia NS-15MS0832B Speaker  Replacement: passo 3, immagine 1 di 1
    • Gently set the tablet screen-side down.
    • The speakers can be located at the bottom of the tablet, below the battery.
    • Using a screwdriver, remove the five 1.2 mm Phillips #1 screws that hold the speakers to the tablet.
  4. Insignia NS-15MS0832B Speaker  Replacement: passo 4, immagine 1 di 1
    • Once first speaker has been removed, remove the other speaker opposite from it.
  5. Insignia NS-15MS0832B Speaker  Replacement: passo 5, immagine 1 di 1
    • Once faulty speakers have been unscrewed, disconnect the speaker and attach the new speaker to the mother board.
Conclusione
Texas Tech, Team 1-1, Bennett Fall 2016 Membro di Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 233
