Salta al contenuto principale
Insignia Flex 8 NS-P16AT08 Back Casing Replacement
Cosa ti serve
  1. Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: passo 1, immagine 1 di 3 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: passo 1, immagine 2 di 3 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: passo 1, immagine 3 di 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Back Casing Replacement: passo 2, immagine 1 di 1
    • Lift the back casing away from the screen.
    • Set casing aside.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 601
