Salta al contenuto principale
Insignia Flex 8 NS-15AT08 Battery Replacement
Cosa ti serve
  1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: passo 1, immagine 1 di 2 Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Battery Replacement: passo 2, immagine 1 di 2 Insignia Flex 8 NS-15AT08 Battery Replacement: passo 2, immagine 2 di 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: passo 3, immagine 1 di 2 Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
  4. Insignia Flex 8 NS-15AT08 Battery Replacement: passo 4, immagine 1 di 3 Insignia Flex 8 NS-15AT08 Battery Replacement: passo 4, immagine 2 di 3 Insignia Flex 8 NS-15AT08 Battery Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
  5. Insignia Flex 8 NS-15AT08 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
Conclusione
Altre 4 persone hanno completato questa guida.
Jeremy Anaya
Membro da: 09/23/15
316 Reputazione
2 Guide realizzate
Baylor, Team 6-7, Williams Fall 2015 Membro di Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,918
